MikeDierbeck
- Apr 15, 2002
Hi-
I have an STR-DE975 Sony receiver with JBL S38's as the two front speakers, JBL S-CENTERii, rear speakers, and SVS 20-39PCi.
On my receiver, it has a function where I can individualy set each speakers crossover (I have the SVS one disabled before anybody asks). I have all of the speakers at 80Hz, but have the LFE HIGH CUT FILTER > STD (which is 120Hz) because that's what the manual has. Is this the correct setting?
Also, would there be any harm in setting the crossover of the center to 90Hz and the fronts to 70Hz? Or even keep the center at 80Hz and drop the fronts to 70Hz?
What would you suggest if you had my system?
Mike
Mike
