LFE channels output
Discussion in 'AV Receivers' started by PaulCAN, Feb 14, 2006.
  1. PaulCAN
    PaulCAN Auditioning
    Feb 7, 2006
    2
    I'm a little new in this area, but beside speaker placement, what should my LFE channel be set at to get the maximum bass through a powered subwoofer? Is the negative (lower) settings more bass?
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    It works the same as all the other speaker settings; + turns it up, and - is down. Ideally, all of your speakers would be calibrated to put out the same level at your listening position. This is generally done with an SPL meter if you don't have a receiver that does this automatically. What receiver?
