Tim_Midnite
- Oct 1, 2002
Hey.....when you play a DVD in DD 5.1, do you want to set the receiver for LFE only to go to the Sub? If you don't, I suppose you're not really getting true 5.1, is this right? If you don't set it up that way.....all the bass level under 80hz from your other speakers will transmit through the Sub and then you'll just have 6 and not 5.1? This Home Theater stuff is confusing me!
