LFE = bass ???
Discussion in 'Archived Threads 2001-2004' started by umit, Jan 31, 2003.
  1. umit
    umit Extra
    Mar 18, 2002
    19
    Just curious..
    what exactly frequance range contains LFE? 10-30 Hz? .. 10-40 hz?.. or 10-80 hz? (if crossover set 80). If so, can we say LFE means: all the bass??? (all the bass we get from a movie)
    I appreciate any info.. thanks
  2. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    LFE = Low Frequency Effects
    In a 5.1 Setup (or any .1 setup the .1 is the LFE Track)
    The fairly standard crossover (when running all mains and
    surrounds as small would be 80hz anything lower is directed
    to the LFE Channel)
  3. umit
    umit Extra
    Mar 18, 2002
    19
    so we can name all the bass below 80 hz. as -LFE- .. right?
  4. umit
    umit Extra
    Mar 18, 2002
    19
    ..if we set crossover 80 hz. of course..
  5. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Depends on the unit doing the crossover I think. But for most I believe LFE is 120hz and down. This 120hz is a brick wall. They don't record any frequencies above 120hz on the .1 channel of a DD or DTS sound track. So unless your processor routes the LFE signal through your mains to the bass management crossover, LFE will be 120hz and down while all your other speakers set to samall will go through the bass management crossover which depending on the processor can be from 40hz to 200hz.
  6. Brett DiMichele
    Sep 30, 2001
    3,181
    Dustin is correct it depends on the Processor. Generaly
    anything THX Certified crosses at 8ohz and even some non
    THX units go with the 80HZ XO but then there are others
    that use 100Hz and 120Hz so it basicaly depends on the model.
  7. Dan Hine
    Dan Hine Screenwriter
    Oct 3, 2000
    1,312
    Here is how I understand it...if someone knows better then feel free to correct me.
    As Dustin alluded to, the LFE channel is IT'S OWN track. There is information specifically recorded to this track which is generally 120hz and down (though that doesn't mean it HAS to have 120hz information, just that it can). So, if the LFE track has 120hz information on it, then to an extent it won't matter where the crossover on the processor is set. If the crossover is set to 80hz on the processor but the LFE track contains 120hz information then the sub will receive unfiltered non-sloped 120hz information since it is supposed to be there and no where else. LFE bass is different than re-routed bass in this respect. Bass that was mixed into the LCR channels that gets re-routed will be sloped around the crossover point since both/all speakers will be reproducing these frequencies.
    Did I make sense (yeah, it could probably be worded better)? Would it seem reasonable that I'm correct? :b
  8. Mike Sloan
    Mike Sloan Second Unit
    May 18, 2002
    456
  9. Mike Sloan
    May 18, 2002
    456
    actually...Dan said it better!
  10. Phil Iturralde
    Phil Iturralde Screenwriter
    Oct 7, 1998
    1,867
    FYI: From Dolby Labs Technical Information website ... What is the LFE channel?
  11. Dan Hine
    Oct 3, 2000
    1,312
    Thanks Mike! Yes, it is important to remember that the LFE track is the .1 in 5.1 (or 6.1, 2.1 etc..) Those fancy numbers refer to Discrete channels. Whatever is recorded on that track is the LFE, the bass being crossed over is just additional information (given to the sub, from the other channels).
  12. umit
    umit Extra
    Mar 18, 2002
    19
    thanks for replies.. and thanks for the link phil..
  13. Edward J M
    Edward J M Cinematographer
    Sep 22, 2002
    2,031
    In theory, the LFE channel can contain information up to 120 Hz.
    I would think bass at 120 would be fairly easy to locate in the room - giving away the position of the subwoofer. Also, the most common filter point for setting your speaks to "small" is 80 Hz per THX recommendations. It doesn't make much sense for the sub to be playing up to 120, while the rest of the speaks play down to 80.
    Theoretical possibilities aside, in practice would it be safe to assume the LFE channel generally contains no significant signal content above 80 Hz?
    Ed
  14. yung cheng
    yung cheng Extra
    Oct 4, 2002
    23
    I have a question about LFE.
    In my case
    spec for my main______40hz~20khz(+-3db)
    rear______70hz~20khz(+-3db)
    center____100hz~20khz(+-3db)
    sub_______38hz~160hz(+-3db)
    receiver HK520 setup
    main____________large
    center__________small
    rear____________small
    sub_____________LFE
    sub xover_______60hz
    sub connection:receiver sub pre-out to sub LFE in
    If i play dolby prologic II(or logic 7 or dts neo), will it deliver all signals between 60hz and 100hz to LFE or individual channels(rear, center, etc)?
  15. Phil Iturralde
    Oct 7, 1998
    1,867
  16. Lee Carbray
    Lee Carbray Second Unit
    Oct 23, 2002
    308
  17. Mitch Stevens
    Mitch Stevens Supporting Actor
    Apr 27, 2002
    581
    I have to agree with what Lee said about your Center and your crossover.
    Most centers out there go much lower than 100hz...I'm wondering if this thing is EXTREMELY tiny. Mine goes down to 50hz, and mine is kinda small, but large to the back.
    Also, your mains don't go low enough to be set to large. I think you should only set to large if your mains can go down to 20 hz. Hmm....maybe someone else will comment on this.
  18. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
    yung cheng: is there a setting for LFE + (L+R) for your sub on the AVR520? That might be a better choice for you than just LFE.
  19. yung cheng
    yung cheng Extra
    Oct 4, 2002
    23
    If I set front speaker=large in HK 520, what is the difference between sub out=LFE and sub out=LFE+(L&R)?
    Do I still connect my sub Polk psw-350 with LFE in or with L&R in or connect all three (LFE, L & R line-in) together to HK sub out?
    thx for the reply
