dave alan
- Aug 30, 2002
The only pre/pro I'm aware of that allows for mono or stereo RB sub(s), AND a discrete LFE sub, is the Lex MC-12.
Unfortunately, I believe it was configured this way to allow for their proprietary 'Bass Enhance' feature to work properly, and therefore, little is said in the manual about the advantages of a discrete LFE sub system.
At the very least, it lends some proof to what I've been saying for a long while. That is, summing the RB (or, as Lex refers to it, 'derived bass') with the LFE signal alters the end results of reintegration of RB with the sats and, as such, should be kept discrete through playback.
Short of buying the pricey Lex pre/pro, I've decided to design and build an analog version of mono or stereo RB sub(s) + LFE router/processor, and versions thereof.
I will post results when complete, for those interested.
Edward...I was referring to my Dolby Manual where, regarding mixing/monitoring (LFE), it calls for "a 6th or 7th order LP filter at 120 Hz.", by no means a brick wall.
However, after reading your post, I thumbed through to find that it does indeed say that, during encoding, " A
brick wall filter @ 120 Hz. is implemented".
Sorry for the mistake, and thanx for pointing it out.
I was trying to point out that the .1 channel of MC SACD/DVD-A has no such limiter applied as a standard, which fact is not addressed in the BF/Dolby article. Nor does the article address the various effects of combining RB+LFE+10 dB into 1 sub system.
By no means is my intent to dissuade those who 'buy it, place it, EQ it and sit back and enjoy their system'. This is a good thing...for them.
