Lexicon Owners: Does your's make a sound?
Discussion in 'Archived Threads 2001-2004' started by Christopher Lyn, Jan 2, 2002.
  1. Christopher Lyn
    Christopher Lyn Stunt Coordinator
    Jan 1, 2002
    124
    I just purchased a used Lexicon MC-1 with the version 1 software. I don't believe there are any defects. Everything seems to be working well except for a low amplitude, high-pitched ringing sound that is emanating from the unit. This sound is emitted while the MC-1 is on or in standby mode. I notice that if I put the front panel leds to 100% the sound is almost completely gone. It's louder when setting the front panel to 25%, 50% or 75%. The sound is similar to that of the Philips Pronto when the backlighting is turned on. (put your ear next to the Pronto and one can hear the noise).
    Is my MC-1 defective? Has anyone noticed this anomaly with any of the MC-1s or even DC-1s or DC-2s?
    I'm still waiting for a response from Lexicon (it's been a couple of weeks).
  2. Shawn Sefranek
    Shawn Sefranek Second Unit
    Sep 30, 1998
    258
    My Lexicon DC-1 w/ Ver 4.0 software is DEAD quiet except for when it’s decoding a DTS signal.
    Only then I can hear the decoding chip cooling fan which has a slight “whine” during extremely quite passages in the movie.
    I believe Ver 1 on the MC-1 is the same as Ver 4.0 on the DC-1 & DC-2.
    Shawn S
  3. Zbigniew
    Zbigniew Stunt Coordinator
    Jan 8, 2000
    185
    MC-1, ver 4.0, dead quiet...
    _zjt
  4. Stacy Huff
    Stacy Huff Second Unit
    Jul 13, 1999
    378
    You should post this over on the Lexicon forum here:
    http://www.smr-forums.com/
    You may have to sign up to post, but it's free.
    Also,I'm pretty sure that version 1 on the MC-1 isn't the same as version 4 on the DC-1/DC-2. Version 4 is the same on all three units.
  5. Christopher Lyn
    Jan 1, 2002
    124
    Hmmm...thanks people..and thanks Stacy...I will post a message over at smr-forums.com
  6. Christopher Lyn
    Jan 1, 2002
    124
    I got a reply fromt the lexicon support. Here is what they emailed me:
    "There will be some noise form the display do to its nature
    Some are louder than others
    I would not worry about it this is normal
    JimC"
    Hmmm...guess I just got one of the noiser ones[​IMG]
