Lexicon NT512 ( Bryston 9bst ) 5 channel amp
John-Tompkins
This Lexicon NT512 is in excellant conditiion cosmetically and functionally, it includes orig. box/packaging. It is a little over 4 years old and has been well cared for. This amp is made by Bryston ( 9bst ) for Lexicon and the only differences is the Lex is thx certified and says lexicon on front. This is the 17'' version without rack handles and is black in appearrance. I have 97 positives and no negatives on ebay under psujohny. Shipping is set at 45.00 in The Cont. US only and I except paypal. Email to discuss paypal compromise's. Im located in Northern Va. (closer to Fredricksburg ) if somebody wants to pick it up. Please email [email protected]
PRICE 1788.00 .. (Orig. retail was 4495.00)
Description and details below:
NT Series now to the point where amplifiers designed for music are increasingly inadequate for reproducing audio/video soundtracks. They simply lack the necessary combination of clarity and brute audio power to faithfully re-create film dynamics — a situation likely to worsen as A/V sound sources improve. This is why Lexicon has developed the NT Series of THX Ultra®-approved power amplifiers. The huge reserves of power in the NT amplifiers provide more than ample headroom, and are perfectly suited to support the extended dynamic range inherent in these
new formats. The vanishingly low noise of these amplifiers
assures the quietest, cleanest power imaginable, while their
awesome authority results in precise control over any
loudspeaker. NT amplifiers have been designed and manufactured for absolute linearity and stability. Utilizing a unique of connections and configurations are accommodated, as well as unique features specific to complex multi-channel audio systems.
We believe that an amplifier’s goal is simple: to amplify
the signal, accurately and cleanly, into any load, without
imparting any coloration or distortion. Indeed, the distortion components of the Lexicon NT power amplifiers push the limits of sophisticated test instruments. More significantly, their sound can best be described as utterly neutral. While the amplifier’s goal is simple, its job is not. Over twenty years of amplifier research and design have
resulted in products that perform flawlessly, year after year. Sophisticated engineering, manufacturing, and testing are combined with meticulous craftsmanship and pride, so
you can enjoy the music and the movies — and forget about
the equipment.
Complete specifications:
S/N: > 110dB
IM + THD: < 0.01%
Input Sensitivity: 1V for 28.28 VRMS
(Approximately 100 watts into 8½)
Input Impedance: 50 k½
Slew Rate: 60 V/µs
Damping Factor: Individual mode: > 500 (20Hz into 8½)
Bridged mode: > 250 (20Hz into 8½) (212, 225)
Radiated Interference: < 3 gauss RMS within 2"of case
Polarity: Non-inverting
Controls and Indicators: Power on/off
3-color LEDs indicates operational status
Toggle switches for bridged/individual operation
(212, 225)
Balanced/unbalanced operation (all models)
6-position rotary switch for remote trigger delay
(212, 225)
General Dimensions: 512: 17.0" W x 5.25"H x 17.0"D
212: 17.0" W x 5.25"H x 9.0"D
225: 17.0" W x 5.25"H x 15.5"D
All models available with 19" x 3U high;
rack mount faceplate
Weight: 512: 60lbs net; 65lbs shipping
212: 22lbs net; 26lbs shipping
225: 40lbs net; 45lbs shipping
Power Requirements: 120VAC, 60Hz
“THX” and “Home THX” are trademarks
of LucasArts Entertainment Company.
The NT 512 Power Amplifier
The 512 contains five 120 watt amplifiers (200 watts into
4ohms) which can be used to run an entire five channel home
theater system. Although housed in a single chassis, the 512
suffers none of the performance compromises typical of
multi-channel amplifiers. Consisting of five amplifier
modules, each with its own separate toroidal power transformer,
the 512 is capable of the same exceptional low noise,
high current performance that is characteristic of all NT series
amplifiers. In systems requiring more than five channels, it
can be seamlessly integrated with other NT series amplifiers.
The 512 is equally suited for music or movie soundtracks,
reproducing even the most demanding source material with
authority and finesse.
All NT amplifiers accept RCA-type unbalanced phono
type plugs, XLR balanced and 1/4 inch tip/ring/sleeve
balanced connectors. All connectors are gold plated for
maximum corrosion resistance. Input gain structures are
matched to connection type via a rear panel slide switch.
Output connectors are heavy-duty gold plated binding
posts which can be used with bare wire, pins or banana
type connectors.
A Signal Ground Lift is also provided, extremely useful in
reducing hum caused by ground loops which are common
in complex systems (212, 225).
NT amplifiers have superb AC line filtration (one of the
reasons for their remarkable dynamic range), and massive
rugged chassis to eliminate environmental interference.
A remote low voltage (5-15v) trigger sensor is included on every
model, eliminating the need for an external power sequencer.
NT SERIES SPECIFICATIONS
New sound sources and digital formats, especially those associated with home theater, are placing greater demands on power amplification - to the point where amplifiers designed for music are increasingly inadequate for reproducing audio/video soundtracks.They simply lack the necessary combination of clarity and brute audio power to faithfully re-create film dynamics; a situation likely to worsen as A/V sound sources improve. This is why Lexicon has developed the NT Series of THXÐ-approved power amplifiers.
The huge reserves of power in the NT amplifiers provide more than ample headroom, and are perfectly suited to support the extended dynamic range inherent in these new formats. The vanishingly low noise of these amplifiers assures the quietest, cleanest power imaginable, while their awesome authority results in precise control over any loudspeaker.
NT amplifiers have been designed and manufactured for absolute linearity and stability. Utilizing a unique Quad-Complementary output stage, the amplifiers produce less distortion than even Class A designs, with higher efficiency and better long term reliability. A wide variety of i/o connections and configurations are accommodated, as well as unique features specific to complex multi-channel audio systems.
We believe that an amplifier’s goal is simple: to amplify the signal, accurately and cleanly, into any load, without imparting any coloration or distortion. Indeed, the distortion components of the Lexicon NT power amplifiers push the limits of sophisticated test instruments. More significantly, their sound can best be described as utterly neutral.
While the amplifier’s goal is simple, it’s job is not. Over 20 years of amplifier research and design have resulted in products that perform flawlessly, year after year. Sophisticated engineering, manufacturing, and testing are combined with meticulous craftsmanship and pride, so you can enjoy the music and the movies and forget about the equipment. All NT amplifiers accept RCA type unbalanced phone type plugs, XLR balanced and 1/4 inch tip/ ring/sleeve balanced connectors. All these connectors are gold plated for maximum corrosion resistance. Input gain structures are matched to connection type via a rear panel slide switch.
Output connectors are heavy duty gold plated 5 way binding posts which can be used with bare wire, pins, lugs, or banana type connectors.
A Signal Ground Lift is also provided, extremely useful in reducing hum cause by ground loops which are common in complex systems.
NT amplifiers have superb AC line filtration (one of the reasons for their remarkable dynamic range), and massive rugged chassis to eliminate environmental interference.
A remote low voltage (5-15v) trigger sensor is included on every model. Power-on can be immediate, or delayed 1,2,3, or 4 seconds, eliminating the need for an external power sequencer.
All accept RCA-type unbalanced phono, XLR balanced and 1/4-inch TRS balanced connectors; all connectors are gold-plated. A signal ground lift is provided for reducing hum caused by ground loops. AC line filtering and a remote low voltage (5-15v) trigger sensor is included with every model.
RichCMovies
