Lexicon MC-12 - I Have a Few Questions
Discussion in 'Archived Threads 2001-2004' started by David Schamis, Aug 31, 2001.
  1. David Schamis
    David Schamis Stunt Coordinator
    Jul 21, 1999
    55
    This looks like it could be the pre-amp to beat, but I have a few questions:
    1. Does the analog by-pass allow for bass management? Specifically on 2-channel sources?
    2. Does the video switcher allow Composite to S-Video, and vice versa conversion?
    3. Do the digital outputs only work on digital sources, or on analogs as well?
    These are some of the features that appealed to me in the Anthem AVM-20, that I would expect the MC-12 to include.
    David
  2. Curtis_Edwards
    Curtis_Edwards Stunt Coordinator
    Jan 1, 2001
    101
    I too will be curious to hear the answers to these questions.
  3. Paul Hillenbrand
    Paul Hillenbrand Screenwriter
    Aug 16, 1998
    1,873
    605
    1,610
    Paul Hillenbrand
  4. David Schamis
    Jul 21, 1999
    55
    I've read both the manual and the brochure and the answer to these three questions is still not clear.
    Anyone have any idea?
    David
  5. Andy Kim
    Andy Kim Second Unit
    Oct 4, 2000
    251
    Try SMR Forums: http://www.smr-forums.com
    They have a dedicated Lexicon discussion group with plenty 'o experts on the Lexicon. I think its officially supported to by Lexicon.
  6. Philip Brandes
    Philip Brandes Stunt Coordinator
    Nov 28, 1999
    81
    10
    Hi David,
    Here are the answers to your questions:
    For each analog input (2-channel and 5.1) you have two options: (1) true analog bypass, which goes directly to the outputs with only volume control (no bass management in this option); and (2) high-resolution 96/24 A/D conversion, which enables bass management, time alignment, and any of the effect modes.
    Only downconversion from S-Video to Composite.
    They will work on analog inputs as well as digital. An internal sampling rate converter allows you to specify digital output rate at 44.1, 48, 88.2, or 96 kHz (or automatically match the sample rate of any digital input).
    Hope this helps.
    If you have more questions, feel free to come by our Forum and post there!
    Cheers,
    Philip Brandes
    Lexicon Owners Forum Moderator www.smr-forums.com
