lexicon dc-1 4v or 2.1v
Discussion in 'AV Receivers' started by BarOr, Jul 26, 2004.
  1. BarOr
    BarOr Stunt Coordinator
    Apr 18, 2004
    74
    Do anyone knows what is the difference between the version?
    Is it worth spending more money on the 4v?
  2. JohnSmith
    JohnSmith Supporting Actor
    Apr 8, 2003
    554
    Not too sure about what the different firmware entails (ask on SMR Forums), but if you do buy a DC-1 MAKE SURE it has the DTS board fitted. These are incredibly expensive, so getting a DC-1 + DTS board will be pratically the cost to what DC-2's are going for nowadays.
    Personally I wouldn't buy a DC-1, look around for a DC-2 (latest v4 firmware, DD & DTS options). It has many more digital inputs.
    I know Version 4 firmware has THX EX, improved Logic 7, and AV Sync delay (I own a MC-1 V4)
  3. BarOr
    Apr 18, 2004
    74
    What is wrong in dc-1 that include dts,ac-3,dpl,logic 7
    (7.1 ?) and thx?
  4. JohnSmith
    Apr 8, 2003
    554
    Nothing wrong with them, it's just that the demand for DC-1's is much less, therefore if you decide to sell it off you're very much unlikely to sell it (more interest in the DC-2) I/O Connectivity is far superior on the DC-2 (also it has triggers) Although if you do buy a DC-1 with version 4 firmware (and DTS board) for about ~£400 that's a good buy. I wouldn't pay more than £500 for a DC-1 though, as a DC-2 with V4 firmware went for £650 a little while ago.
    From what I gather from UK ebay sales anyway.
    Yes a DC-1 has DTS, AC-3, Logic-7, THX - 7.1 channel, just make sure DTS board, and with AC-3 option as well. The basic DC-1/DC-2 are just Pro-Logic & THX. I've seen some of these basic models going, they never sell. Prohibitive to get the upgrades (EEPROM - DC-1/DC-2 & DTS board on DC-1)
    [edit] DC-2 has more S-Video inputs as well. Download the manuals for DC-1 and DC-2 from the Lexicon site and compare the back panel
    http://www.lexicon.com/products/downloads.asp?ID=12
    http://www.lexicon.com/products/downloads.asp?ID=7
    [edit2]
    My MC-1 arrived with early f/w, I then got V4 EEPROM FOC. Couple of things I noticed with the earlier f/w that the V4 firmware fixed..
    Digital click on every chapter skip.
    Clicking per dB step when adjusting volume.
    Pop when muting/unmuting Music Logic mode.
  5. BarOr
    Apr 18, 2004
    74
    First of all thank you
    Second I didn't understand if the dc-1 4v has 7.1
    last would you spend the extra 200$ on the 4v rather the 2.1v
  6. JohnSmith
    Apr 8, 2003
    554
    All versions of the DC-1, DC-2 and MC-1 are 7.1. Even the old CP-1,2 & 3 are 7.1 (Pro-Logic, expanded to 7.1)
    There is no hardware difference on the back panel between DC-1 firmware versions. The firmware is a removeable EEPROM, which replaces the existing firmware chip. The add-on DTS board on the DC-1 & DC-2 (fitted as standard on MC-1) slots in on the left hand side.
    How much have you seen a V4 DC-1?
  7. BarOr
    Apr 18, 2004
    74
    I have seen dc-1 4v that cost 800$
    Further more I have seen 2.1v that cost 600-650$
    Thank you
  8. JohnSmith
    Apr 8, 2003
    554
    I would go for the V4 DC-1 (if you can't afford a DC-2), $800 works out at £434, which is a excellent price.
    If 2.1 has the same problems as my MC-1 early f/w -I think spending a bit more on the latest firmware is a wiser choice; those loud clicks & pops were quite worrysome (could damage a tweeter, especially if the master volume is set loud), I muted it whenever I wanted to skip/reverse chapters.
    I've uploaded pics of the DC-1 & DC-2 back panel to a site..
    DC-1 only has 2 coaxial, 2 optical. DC-2 has 5 coaxial, 3 optical. DC-2 has two more S-Video in's, RS232 & 12v trigger block. Do you need more than 4 digital inputs?
    http://nathansilly.012webpages.com/dc1dc2.JPG
    Copy the link to IE, then paste. Do not click the link (doesn't support direct link)
  9. BarOr
    Apr 18, 2004
    74
    I don't need more inputs or outputs (at least for now)
    Thank you [​IMG]
    Further more do anybody know what is exact difference between 2.01v and 4v?
  10. BarOr
    Apr 18, 2004
    74
    Do you know what is the address of this fourm?
  11. JohnSmith
    Apr 8, 2003
    554
  12. BarOr
    Apr 18, 2004
    74
    I did as you said:
    My qustion:
    "Hi,
    > Do any one know what is the difference between the two?
    > Is it worth spending 200$ more on the 4v?
    > Thanks"
    The answer:
    "The differences between V2 and V4 were major--virtually all the surround
    modes were significantly improved, and the remote was redesigned. Most of
    these changes were introduced in V3; V4 introduced THX Surround EX and DTS
    ES (matrix).
    Well worth the price difference--it would cost a lot more to upgrade a V2 to
    V4, if parts are even available.
    Cheers,
    Philip Brandes"
    Anyway thank you
    [​IMG] [​IMG] [​IMG]
  13. JohnSmith
    Apr 8, 2003
    554
    There's a DC-2 V4 on Audiogon for $1000
    I think the $200 more for the DC-2 V4 over a DC-1 V4 is worth it.. :)
  14. BarOr
    Apr 18, 2004
    74
  15. BarOr
    Apr 18, 2004
    74
    By the way do you think that lexicon dc-1 with decent power
    would be a match to denon 3803 (music and home theater wise)?
  16. JohnSmith
    Apr 8, 2003
    554
    Ask the same question on SMR [​IMG] I haven't used a 3803.
    If 2ch Hi-fi is important as well, then I would buy a off-board DAC and a 2ch pre-amp, as I feel HT processors cannot "do" Hi-Fi well :)
