Joe Tilley
- Jan 1, 2002
I tried to post yesterday but I don't know what happened I got a server error when I submitted it so I'll try again.
Anyway I will be getting a RPTV within the next couple of months I have narrowed my choices down to either the new Sony WV600 or 700 series or the Mitsubishi Platinum Plus series. I really like the new Sonys front screen cover & think I might be better off with it because I have a three year old that likes to put his hands all over the tv once in a wile. That & it would be more compatible with my other stuff being all Sony. On the other hand I recently looked at the Mitsubishi sets & was very impressed with the picture quality of them. I would almost say I think they may have had a slightly better picture than the Sony sets, but the Mits were setting in a darker area so that could have been some of it. Anyway one thing that I am concerned with is calibration on the Mitsubishi. Are the service menus on them fairly easy to use? I know how to get around in the Sony service menus & have no trouble with them so I wont to be able to use them on the Mits if I go that route.
The other plus I have noticed is that I can get the Mits in a 65" for just a couple hundred more than the 57" Sony 600 series, but I'm not completely sure whether I wont to go with the 57" or 65" yet.
So I guess what I'm after here is anybodies opion on either or both of these sets. I have heard a lot of good things About the Mitsubishi sets but I have always had Sony stuff & good luck with them so far so I not sure what to do.
Thanks for any help.. Joe
