Less bass in new HT room - need advice!
Discussion in 'Archived Threads 2001-2004' started by Gary Tjia, Feb 21, 2002.
  1. Gary Tjia
    Gary Tjia Stunt Coordinator
    Dec 13, 1999
    62
    Hi,
    I just moved my hometheatre system into a dedicated 15X12X8 room and found that the Paradigm PR12 subwoofer not having as much bass as it used to in a much larger open living room with vaulted ceiling. I did not even adjust the subwoofer setting.
    Any idea why that would be the case? [​IMG]
    Gary
  2. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    It looks like you will have to experiment with sub placement to achieve your desired results. Where was your sub located before and after with respect to the listening position?
  3. Matt Stryker
    Matt Stryker Screenwriter
    Oct 12, 2000
    1,307
    Also note the floor material, carpeting, etc. Concrete and normal wood flooring have very different sonic characteristics.
    Try to get it into a corner if you can.
  4. Chad Anson
    Chad Anson Second Unit
    Feb 13, 2000
    377
    You new room certainly has different acoustics and the sub may be placed in a spot that creates a null at the listening location. One trick for determining a good location for your sub is to place the sub at your listening position and then move about the room measuring the frequency response until you find a spot that has a good response (minimal nulls and peaks). Tools required: sound meter from radio shack and a low frequency test track (the Avia DVD has one for bass response).
  5. Gary Tjia
    Dec 13, 1999
    62
    Thanks for the feedback.
    The new media room has the same type of carpet and wall, except for a lower ceiling (8 ft) instead of a vaulted ceiling. The subwoofer is placed in the left corner wall, next the the left main speaker.
    I had raised the sub setting to +3db on the a/v receiver to increase the bass. It was previously set at 0db.
    I was surprised that the sub did not have more bass in a smaller and more enclosed room.
    Gary
  6. Jim Mc
    Jim Mc Agent
    Sep 3, 2000
    27
    I've read a lot of posts that subs are more powerful in a sealed room. But my experience is that a more open environement increases the impression of bass output. Even opening the theater doors has the effect.
  7. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,357
    293
    Cees Alons
    Gary,
    Chad's advice is an excellent tip. You may also want to play with the phase settings of your sub. Perhaps there's some cancelling out now with other speakers.
    Cees
  8. Wayne A. Pflughaupt
    Aug 5, 1999
    6,100
    33
    Katy, TX
    Wayne
    Gary,
    Your position in relation to the sub can make a difference, especially if you had the seat against the wall in the old room, and now have it in the middle of the room. In the first situation, bass is exaggerated at the listening position.
    Wayne A. Pflughaupt
