- Jul 19, 2002
I've just finished construction of my EBS alignment Shiva. I've made a few modifications to the design, such as using 2 2" ports instead of a single 4" port and tuning it to 20hz instead of 18.1hz (to make the port length more manageable).
Right now I have 2.5" legs on the bottom and i was wondering is enough clearance? If not, how long should the legs be?
I hooked it up to the amp in my truck just to make sure everything sounded right and it sounded as good as could be expected firing down on a concrete basement floor. It will be in a room w/ minimally padded carpet after it's painted and trim pieces are stained and installed.
