StephenP
- May 23, 2001
I have a Sony 53hs30, and the first 2-3 inches of the picture appears to have a problem. The effect looks like the lenticluar screen is bowed slightly inward on this side, and I suppose it actually could be. I have never removed the screens, so Im not sure how flexable they are, or how I would tighten them up if I did open the case. I have tried to adjust this using software, but I cant seem to find any controls that would adjust only one side. Any suggestions? I think my pincusion problems are finally all fixed by using the rpin bpin gpin controls, so horizontal lines are pretty much straight across. Things just seem a bit thin when they move to the left and out of view. Does this make sense? Thanks!
