Leaving amp on 24/7 - Big electricity waste?
Discussion in 'Archived Threads 2001-2004' started by Gregg Hart, Jan 3, 2002.
  1. Gregg Hart
    Gregg Hart Stunt Coordinator
    Apr 15, 1999
    167
    I am having problems getting my pre-amp to trigger my amp on/off. I have decided to leave the amp on all the time. Is this a big electricity drain, when it's left idle with nothing else on? The amp is a Golden Theater GTA-1 with 5X200 watts @8 ohms. Thanks.
    Gregg
  2. Donald Shrum
    Donald Shrum Stunt Coordinator
    Dec 24, 2001
    182
    I am running Arogon 8008X3 amp and an Adcom 2 channel. I used to leave them on 24/7. So I turned them off for a month and my bill went down almost $60. I come to find out that the aragon is running at full power all the time. Thats why it was always hot. The adcom on the other hand didn't get hot unless I was using it. But yes leaving my amps on cost me $60 more a month.
  3. Robert A. Willis Jr.
    Robert A. Willis Jr. Second Unit
    Jul 11, 1999
    306
    Do a search of the forum, this has been discussed at length elsewhere. If memory serves me, don't leave the equipment on 24/7...[​IMG]
    rw
  4. Todd Hochard
    Todd Hochard Cinematographer
    Jan 24, 1999
    2,312
    I can't find any literature out there on the Golden Theater, but given their rep (and price), I'm betting they use Class A operation.
    Class A power amps have the highest idle power consumption of any amps, and can consume upwards of 50% of full power rating, when sitting idle (i.e. on with no signal). As such, it could be upwards of 500 Watts, continuously. That's 360KW-hrs monthly, or about $36 in my neighborhood.
    Why not look into WHY the trigger doesn't work correctly, and fix that?
    Todd
  5. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    I wouldn't leave it on 24/7 since its wasting electricity and costing money. Try to fix the triggering situation. If you cannot, then why not wire a "light-switch" on the wall to control the amp. I have done that for my subwoofer, TV, receiver and CD player and I love it. When I'm not watching TV, a movie or listening to music, it is all turned off. The only thing left on is my VCR which is actually ENERGY rated and only draws a couple watts.
    Avoid using more power than necessary.
  6. MarcVH
    MarcVH Second Unit
    Dec 26, 2001
    324
    Do you heat your house with electricty? If so, in the winter you can leave it on 24/7 and it won't cost much (if any) more than you would otherwise have paid for space heating.
    If you air-condition in the summer, though, the equation reverses and you'll pay not just to power the amp but again to get rid of the heat it produced.
  7. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
  8. Wolf Jenkins
    Wolf Jenkins Stunt Coordinator
    Oct 11, 1998
    161
    You seem to live in CA - it's not worth the convenience to leave it on all the time. So many reasons that lower power consumption here is better - but the cost is definitely tangible. I'd bank the $$ and put it in the upgrade fund! [​IMG]
  9. Oliver
    Oliver Stunt Coordinator
    Feb 28, 1999
    102
    I surely like my Parasound HCA 2003 that is feed by a Denon AVC A1SE. Those are big eletricity consumers too.
    While I see not problem in that as long as it realy gives you pleasure while watching a film or listening to music please shut them down when you do not need them.
    Electricity does not (ok, very few times it does) fall from the sky, it has to be produced and resources are gone forever when wasted. Plus the production of electricity polutes the air and ground, your enviroment and mine also. This will not make earth any better, so take your time to think about that too, if not for you than for your children.
  10. Luis A
    Luis A Second Unit
    Aug 2, 2001
    414
    I leave all 5 of my B&K REF amps on 24/7, and have only noticed about a 19-24 dollar difference. I've noticed most amps do not sound like they should cold. I believe the B&K's consume 75 watts when there is no signal present.[​IMG]
    L
  11. MarkPayton
    MarkPayton Stunt Coordinator
    Apr 15, 1999
    70
    Greg, I suggest you check this recent thread on the same subject.
    The easiest/most efficient solution may just be to turn the amp on and leave it on for the hours you expect to be using it, then turn it off again when you are done. This is what I do with my Samson amp, and at least a few other members seem to do as well. Unless you have a habit of using the amp firstthing in the morning and again late at night, generally your equipment would only be sucking up power for a few hours a day. Plus you'd only have to get up to switch it on/off twice, and at times when you'd already be up anyway.
