Chris PC
- May 12, 2001
My system now:
AMD64 3000+ winchester
1 GB OCZ PC400
MSI Neo2 Platinum
Seagate 7200 rpm SATA 200 GB HDD
Geforce2 GTS (I do not play games)
What are my choices for a very in-expensive AGP video card with DVI and good de-interlacing capabilities for HTPC duty? I do not play games. Could I use:
ATI based 9250, 9200SE or 9550?
or an nVidia based MX 4000 or FX 5200? 6200?
..and achieve good de-interlacing? Which would recommend and why?
It seems to me that if I use an ATI based card, I am able to take advantage of the iDCT hardware acceleration which is similar to Faroudja de-interlacing, correct? That means I don't "need" Theatre Tek to acheive decent de-interlacing. (Right now I have Power DVD and I see that it is poor) If you recommend one of the nVidia cards, which one and what software should I use with it?
I mainly want to test sending a DVI to HDMI signal to my projector, but it would be handy to buy a video card that is somewhat useful for potential HTPC use, if only as a back-up and/or for testing/comparing or possible HTPC use. I do not want to go HTPC right now, I just want to trouble-shoot a DVI>HDMI problem with my regular HT components.
Basically, how cheap can I go with an AGP video card and still have de-interlacing somewhat comparable to Silicon Image or Faroudja? Which card? WHich software?
P.S. I asked this about Radeon only, but I changed my question to include all cards.
thanx
1 GB OCZ PC400
MSI Neo2 Platinum
thanx
