learning remote
Discussion in 'AV Receivers' started by Harry Lincoln, Sep 30, 2003.
  1. Harry Lincoln
    Harry Lincoln Stunt Coordinator
    Sep 29, 2000
    193
    I have a denon 3803, I set the remote up yesterday with codes to control all my components. I want it to learn the codes for going directly to -20db -10db etc on the 3803.
    These codes are not preset into the unit so I will need to buy a remote that has these commands preset and then transfern them to the denon remote.
    What is the cheapest remote available that can do these commands?
    Am I missing something, is there an easier way to do this?
    Thanks.
  2. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    Harry,
    It looks like you might need one of the OneForAll remotes and possibly a JP1 cable to interface with your computer. This is about the cheapest route that I'm aware of to get you to where you need to go.
    Here's a couple of links to get you started:
    HiFi Remote Info.
    Remote Central Site
    Also, under Yahoo! Groups, there is a JP1 group that you might want to join. Lots of files for various gear is placed out there -- you could download them and program them into the OFA remote -- then learn the commands with your Denon remote.
    Best of luck !
  3. Harry Lincoln
    Sep 29, 2000
    193
    Thanks Wayne.
