Eric_L
- Nov 2, 2002
- Eric
I soooo hate installing the water filter behind my fridge. I can never seem to get it to not leak without multiple attempts. Always the fittings leak...
I thought I'd avoid the trouble this time and I had a plumber install it during my home restoration. I bought a three year filter for good measure...
Well, today it starting leaking. AAAAIGH!
I have a copper pipe running to the filter and to the fridge. It is clamped down tighter than a ... well, it's tight.
Any ideas on why it is leaking and/or a sure way to fix this?
