KeithA
Grip
- May 14, 2001
Hi all,
I have some newbie'ish questions about using my new LCD projector in my small apartment... I've been using it primarily as a big computer screen (a cordless optical mouse came on the market just in time ), but I'd like to also be able to use it in a make-shift home theater type setup. Projector is 900lumen,XGA,400:1 contrast... Questions are:
Is it possible to use a flat second surface mirror to reflect the projected image? (the variety you find for bathroom walls at home depot) How much do you lose in terms of brightness and sharpness? Large first surface mirrors I've seen are too expensive for me and harder to care for I would imagine.
My projector accepts component signals only through a special cable that goes to the HD15 connector that my computer connects to. I'd rather not be pulling the connector every time I want to switch. What would be the best way around this? Options I see are to use those mechanical VGA switchboxes (which would probably introduce ghosting in my monitor signal... what would it do to the component signal?) or run the DVD signal over Svideo.
I've seen it suggested a number of times to use one of those radio shack AV selectors as a poor man's component video source switchers. Does that work in reverse? (1 video source, 2 outputs)
Would an acoustically transparent screen be too low in gain for this projector? Are they much more expensive?
How acoustically transparent is a stretched thin bedsheet? I like the cool factor of having a center channel behind the screen (altho watching a bedsheet might remove the cool factor).
Thanks for any info... I have the projector. Now I just need surround speakers, a receiver, a screen...
