Hey guys, my name is jason and i have a dilemma of sorts here. One of the managers where i work at has asked me to do an installation in her home. The idea here is quite simple in her mind but not as simple in mine. She has an addition off of the living room and it has a sunken hot tub in the floor. She wants an LCD screen, 32", set into the wall at what would be ankle up to knee level if you were standing on the floor. The wall is approx. 10 inches from the edge of the hot tub. She wants it set in the wall with a lexan protector over the front. The issue i have is that i believe the lexan will fog up easil. The tv will be completely sealed off from that room however with some duct work to pull out the heat created by the LCD as well as a couple computer fans plumbed to an intake vent to provide some cool air. I suggested the option of using a projector to eliminate the need to cut into the wall at all but she is resisting my advice. I don't really want to be liable for any issues that arise from the LCD option but i do want to help her out. Any opinions or suggestions?
