LCD Monitor - how serious is this defect
Discussion in 'Computers' started by John Watson, Oct 21, 2005.
  1. John Watson
    John Watson Screenwriter
    Jul 14, 2002
    1,937
    I just got a new computer, bundled with a 17" flatscreen monitor.
    I immediately noticed a 'missing pixel', a tiny pin-point size green dot in the screen before the wallpaper comes up.
    It's not noticeable on most screens when I'm using programs, so, should I return it, or is this within normal performance for LCD displays?
    TIA for opinions / advice.
  2. Christ Reynolds
    Christ Reynolds Producer
    May 6, 2002
    3,597
    CJ
    it's a dead pixel, and is fairly common with lcd displays. check the return policy about dead pixels. if it isnt noticeable during most programs, i wouldnt worry too much about it.
    CJ
  3. Jason Harbaugh
    Jason Harbaugh Cinematographer
    Jul 30, 2001
    2,968
    And depending on who you got it from, and the manufacturer, they all have different return policies with dead pixels. Some require as many as 8 or 10 dead pixels before they replace it, while others only require 1 or 2.
    A great utility to check your monitor is LCDTest
  4. John Watson
    Jul 14, 2002
    1,937
    Thanks guys.
    The monitor has a 3 year warranty so I guess I won't worry unless the problem spreads.
  5. MarkHastings
    MarkHastings Executive Producer
    Jan 27, 2003
    12,013
    I would definitely try to return it, but don't get discouraged if you find out you can't. Dead pixels are common, even with new equipment.
  6. Christ Reynolds
    May 6, 2002
    3,597
    CJ
    it won't spread, the pixels are pretty much individual elements. dead pixels do not affect other pixels, so what you have now is what you will likely have forever.
    CJ
  7. Jason Harbaugh
    Jul 30, 2001
    2,968
    There's also the 'massage' method of getting the pixel to work again. [​IMG]
