LCD flat panel TV's?
Discussion in 'Archived Threads 2001-2004' started by Chris PC, Sep 27, 2001.
  1. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Is there such thing as a flat panel LCD 16:9 HDTV TV? I know they have LCD displays, but do they have TV tuners in them? What are some examples of some LCD display brands?
  2. KyleS
    KyleS Screenwriter
    Jul 24, 2000
    1,232
    Really for quality flat panel TV units above say 18" you should be looking at Plasma TV's and not LCD. Keep in mind that for most people these are not a cost effective solution. A much cheaper & Bigger way to go would be a front projection system with a drop down screen IMO. The one bad point to this is you need some light control and with the Plasma units you dont.
    KyleS
  3. Scott Dautel
    Scott Dautel Second Unit
    Oct 6, 1998
    471
  4. Phil A
    Phil A Producer
    Oct 1, 2000
    3,171
    38
    Central FL
    Phil
    Samsung (www.samsungusa.com) makes some LCD projectors. They are narrower than conventional rear projection sets but not flat like a plasma display. The 40 inch widescreen in my bedroom weighs 59.5 lbs. and is only 13.75 inches deep. The main drawback of such designs is that it is likely that every few years there may be a need for a bulb replacements that may be a little over $200. The quality of the picture is very good. Sony is coming out with a 60 inch LCD projector that is 21 inches deep and weights 132 lbs. It should be out in a month or so. I think it will retail for $8k.
