LCD dead pixel
Discussion in 'Displays' started by Wayde_R, Mar 29, 2005.
  1. Wayde_R
    Wayde_R Stunt Coordinator
    Aug 25, 2003
    244
    I understand that the way LCD panels (and chips for projectors) are made that they have a certain amount of dead pixels that are considered an acceptable loss. Like rat turds in your canned ham, a certain amount is considered okay.
    I read the support bulletin on Sony's site, I own a Sony so I've been reading their support info, no I don't currently have this problem.
    http://129.33.22.16/SRVS/CGI-BIN/WEB...Sxi=1,Case=obj(312288),UseTemplate=Case.tem
    but it's a bit alarming. They refer to the dead pixel as a "structural property" and hence it's not a warranty item.
    I've heard two things about this... help me sort out salesman schlock from the real 411:
    First, I've heard that pixels (on LCD) don't just "go bad", they're born bad. So, since my TV is free of dead pixels it's not likely to be a problem for me.
    Second. My salespeople told me that they'd replace my LCD RP if a bad pixel appeared. Is this true? I don't have it in writing but I do have a warranty in writing, I'm positive it doesn't cover a dead pixel because of what I read by Sony. How can my retailer override the manufacture?
    I am curious if anyone's ever been screwed by this? It seems that given the nature of this problem if you're buying an LCD you should really make sure you get a good look at the unit you're buying before plunking down the cash.
    Thanks in advance for any shared experiences or knowledge.
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    Most retailers would allow a return within a certain time frame if for any reason your not happy.
    Not sure beyond that. I know if I got a display and it had dead pixels I could see. I'd return it. As your wondering, of course, a total different story if it happens after a year I suppose.
    1 or 2 out of how many? Man, seems like it would be hard to even see this with the naked eye. But I don't really know.
    Come on LCD gurus!!! I guess I'd like to know as well.
  3. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Sony has worked with the 12 dead/stuck pixels per sq inch rule for some time.
    User manuals often state that a few dead pixels are considered to be acceptable and within spec.
    These things are not sold as being perfect.
    (And we are reminded that there are 3 million of these pixels ... and they die sometimes ... just like heat tiles fall off space shuttles)
    Regards
  4. Wayde_R
    Aug 25, 2003
    244
    Thanks for the input guys. It's good to know some of the inside info like the exact number of pixels per square inch, interesting.
    I guess it's not too common.
    Wayde
