Large box sealed subs...
Discussion in 'Archived Threads 2001-2004' started by Dan M~, Nov 14, 2002.
  1. Dan M~
    Dan M~ Second Unit
    Nov 30, 2000
    356
    2
    What are the advantages/disadvantages of large volumned sealed subs? I have a Tempest in a 3 Ft^3 sealed box and I am thinking of building a 5 Ft^3 sealed box. What should I expect? What am I gaining and losing?
  2. Assuming heavy fill and no leaks, then going from 3-->5 ft^3 changes your Q from 0.677 to 0.588
    you gain more output below 40hz (+ almost 2db at 20hz), and loose some bass between 40-up....but not very much
    Ultimately, you will have better group delay (good for music), lower Q (0.6 is pretty good for music), lower extention (better for HT), but slightly less upper bass (not as good for HT). You also "gain" the need for less power to reach x-max at 20hz
    anyone else?
  3. Jack*Mains
    Jack*Mains Stunt Coordinator
    Sep 25, 2002
    156
    Stupid question, but: is it necassary to fill a 142.5L sealed sub with polyfill?
    Is the same necassary for vented?
  4. You don't stuff a ported enclosure, but rather line the walls.
    You don't need to stuff a sealed enclosure, but doing so will make it appear larger and may help with the backwave of higher frequency harmonics.
  5. Chris Carswell
    Chris Carswell Supporting Actor
    Mar 5, 2002
    598
    Funny, I stuffed my ported Tempest [​IMG]
  6. Dave_Gib
    Dave_Gib Stunt Coordinator
    Oct 1, 2002
    81
    I stuffed my ported enclosure it acted noticeably bigger
  7. you can lightly stuff a ported enclosure, but I wouldn't recommend a heavy fill!
  8. Chris Carswell
    Mar 5, 2002
    598
    I guess it's what one consider a "heavy fill".
    I've got a Tempest in a 24x27x19 box (~5.8 cu ft). Way too small for its full potential. I didn't feel like making a new box so I stuffed it with 60oz of fill to get the cu. ft up. It's important to keep a clear path to the ports so they don't get plugged up & can work properly.
  9. Dave_Gib
    Oct 1, 2002
    81
    I just added a pound and a half I had around, put it in an 8 cu.ft. ported box for 4 12" Dayton DVC's, I didn't turn it on right away, I kind of forgot about it until later, I noticed the bass was alittle deeper, then I remembered I put that stuffing in it, so I know it wasn't the placebo effect
  10. Dan M~
    Dan M~ Second Unit
    Nov 30, 2000
    356
    2
    Anthony_Gomez,
    Thanks for the info.
  11. Dan M~
    Dan M~ Second Unit
    Nov 30, 2000
    356
    2
    Bump...
    [​IMG]
  12. less upper bass just means that you will end up with a shallower rolloff starting at a higher frequency
  13. Dan M~
    Dan M~ Second Unit
    Nov 30, 2000
    356
    2
    Thanks Anthony...
    Additional questions if you don't mind...
    If I incorporate an LT into the system, it seems that a larger enclosure would require less power then a small enclosure to achieve the same SPL down low. Is this true or am I missing something?
    Thanks again for the guidance.
  14. You are correct.
  15. Jack*Mains
    Sep 25, 2002
    156
    Alright, so one last question:
    If I have a 142.5L sealed enclosure, do I just stuff it in there, or do I line the walls first and then stuff it?
    If porting the same box with the ESB allignment, do I want ANY polyfill in it at all, or just bare MDF?
    In both cases, how much polyfill would be required?
    Thanks a lot.
