Laptop Advice Sought
Discussion in 'Computers' started by Angelo.M, Jan 8, 2004.
  1. Angelo.M
    Angelo.M Producer
    Aug 15, 2002
    4,007
    I'm replacing my laptop, a Dell Inspiron.
    I use the machine primarily for PowerPoint presentations with heavy graphics, audio and moving images. I typically build the presentations on my desktop (a PC) and then bring them over to the laptop.
    I'm considering an Apple laptop, but I need to know that my PP presentations will be 100% cross-compatible between the PC and the Mac. I don't want to build a presentation on the PC and then have to do a major overhaull just to run it on the Mac.
    Otherwise, I'll replace it with another Dell (and yes, I am limited to Dell or Mac). Any suggestions on a particular Dell replacement, and certain features, are welcomed.
  2. Diallo B
    Diallo B Screenwriter
    Dec 18, 2002
    1,076
    if i were to go with a dell, and price was not an issue, i would go with an 8600. check out the specs here:
    http://www1.us.dell.com/content/prod...=19&l=en&s=dhs
    it is a pretty good computer. i had the opportunity to use one for a couple of weeks and was very happy with the performance.
    i am not sure about anything mac as i have not used one since college. GO BLUE!!!
    if i were not limited to those brands and price were not an issue i would check out this toshiba p10:
    http://www.csd.toshiba.com/cgi-bin/t...llite&pmod=P10
    and its big brother p25:
    http://www.csd.toshiba.com/cgi-bin/t...llite&pmod=P25
    i currently own a toshiba laptop (5105-s501) and have played with those above for a few weeks. simply put great computers.
  3. Angelo.M
    Angelo.M Producer
    Aug 15, 2002
    4,007
    Thanks.
    I think I'll be going w/ a Dell Latitude D800. Nice machine.
