Jason Sweet
- Apr 2, 1999
Hi guys, looking for a little expert advice here. I have a 40" LCD widescreen RPTV, the Samsung PLH403W. On Christmas day, as I was showing off Grand Theft Auto 3 on the PS2, The set shut off and the power light blinked for about 20 seconds, and then all three display lights started blinking, indicating the lamp/bulb had gone. I called the East coast service center for Samsung in NJ. They asked for the model number, and I said PLH403W (EXACTLY what it says on the serial number info) and they told me they had nothing like it only W3, W6, etc. They told me to look again, and there is NO number after the W anywhere on the set. I have the service manual, and took the blub out, but there is no info on the bulb itself. I called back, they said they had no idea what to do, especially since it's a no return item.
So..my questions...
I've had the set 2.5 years, is that normal for a lamp to go so fast?
They said the average price for the lamps they had was over $400, is this normal? (it's seems way high.)
What should I do? Take a chance on one of the bulbs? Start looking for a new set?
Once you go 16:9, I don't want to go back. This time I'd go for a tube TV, but those are $2000-2500 for a 34-38". Should I cut back my buying and start saving?
I'm in serious withdrawal after a week of no DVD PS2 or Xbox in my HT. (Thank God for my portable DVD!)
Please, any help will be GREATLY appreciated.
Jason
So..my questions...
Jason
