Krell For Rear Channels?
Discussion in 'AV Receivers' started by Jared Neumann, Jan 2, 2004.
  1. Jared Neumann
    Jared Neumann Stunt Coordinator
    Nov 11, 2003
    60
    I WAS WONDERING IF ANYONE KNOWS IF THIS WILL WORK AND HOW MUCH OF A DIFFERENCE IT WILL MAKE THE SOUND.
    I CURRENTLY AM USING 4 CHANNELS OF AN ADCOM 7807 FOR ME REAR AND SIDE SURROUNDS. I WAS CONSIDERING USING A PAIR OF KRELL 300IL INTERGRATED AMPS IN THE PLACE OF THE ADCOM.
    DOES THIS MAKE ANY SENSE TO DO
    MY THEATER
  2. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    iT tOTTAlly DePeNDS oN wHAT tyPE of SpEAkers yOU ArE RuNNiNG bAcK tHERE aND hOW lOuD yOu LisTen TO thE MoVIe/MuSIc? ChanCES aRe tHOuGH thAT ThE MOnEY spEnT oN uPGRadINg to tHE KRell AmPs fOr REar Duty CouLD beTTer bE sPEnT ON SoME OthER ASpeCT of YOuR SySTem.
    Ps its a lot easier to read posts that aren't in all Caps[​IMG]
    PSS I just went to your site and you've got some nice gear already but really while its a nice goal to have premium amps on all channels given your speakers are set up for HT not SACD or DVD-A I'd argue that the adcom is more then enough amp to do justice to those M&K's. If you were to upgrade anything I'd start with either the subwoofer or more likely the DVD player.
