Korean Saving Private Ryan LE and widescreen ratio
Discussion in 'DVD' started by Aaron Schmitt, Oct 10, 2003.
  1. Aaron Schmitt
    Aaron Schmitt Stunt Coordinator
    May 26, 1999
    203
    I was wondering if anyone had more information about the SPR LE disk that is available in Korea? At Koreandvds.com http://www.koreandvds.com/dvddetail.html?id=11359 they list it as a 1.78:1 aspect ratio, while the film has a 1.85:1 ratio. Did they change the AR for this release, or do they have the wrong ratio listed?
    Thanks for any help,
    Aaron
  2. Julian Lalor
    Julian Lalor Supporting Actor
    Oct 5, 1999
    975
    You'll find most 1.85:1 films are transferred at 1.78:1 in most regions (including R1) to fit the dimensions of a WS TV. There is nothing unsual in the SPR transfer in this regard.
  3. CraigL
    CraigL Screenwriter
    Jan 16, 2000
    1,863
  4. Julian Lalor
    Oct 5, 1999
    975
  5. Aaron Schmitt
    May 26, 1999
    203
    Julian: maybe you should check your widescreen tv for overscan with Avia or Video Essentials. A 1.85:1 aspect ratio might look like 1.78:1 depending on a tv's overscan. I have yet to see any region 1 1.85:1 dvd's transferred at anything other than that ratio either.
    To get back on topic, hopefully someone who has the disk, or has seen it, can comment on the ratio. If it is 1.78:1, that's a shame and I'll just keep my region 1.
  6. Julian Lalor
    Oct 5, 1999
    975
  7. Andy_G
    Andy_G Stunt Coordinator
    Jun 29, 2000
    212
    Look at R1 Empire of the Sun, that disc is definitely matted only to 1.78:1. There is no cropping involved and the difference is minimal.
  8. CraigL
    CraigL Screenwriter
    Jan 16, 2000
    1,863
    Julian...
    Again...completely disagree. I have The Godfather Trilogy and THAT is 1.78...not 1.85. I think you've gotten things mixed up.
  9. Julian Lalor
    Oct 5, 1999
    975
  10. CraigL
    CraigL Screenwriter
    Jan 16, 2000
    1,863
  11. Roger Mathus
    Roger Mathus Supporting Actor
    Sep 1, 1997
    548
    Central Oregon
    Roger Mathus
    I have the Korean SE of " Saving Private Ryan" . The package is indeed marked 1.78. The DVD is excellent but I don't bother to check anymore whether the actual picture is 1.78 vs. 1.85. To me it does not make any difference but it seems that most 1.85 DVDs (including Region 1) are likely 1.78. I use a projection system with Marantz S2 on 7 ft screen. By the way, the Korean SPR is coded Region 3. I do, however, object to 2.35 aspect ratio films presented at 1.78. There are a few of those out there.
  12. Julian Lalor
    Oct 5, 1999
    975
  13. CraigL
    CraigL Screenwriter
    Jan 16, 2000
    1,863
    But none of this proves that 1.85:1 doesn't exist. Isn't that your point? You said...
  14. Julian Lalor
    Oct 5, 1999
    975
  15. CraigL
    CraigL Screenwriter
    Jan 16, 2000
    1,863
    Whatever.
    NONE of this makes a majority. So you're saying that 1.85:1 has ALWAYS been wrong? On laserdisc? On VHS? They're always transferred incorrectly? That's absurd.
  16. DeanWalsh
    DeanWalsh Second Unit
    Apr 17, 1999
    390
    @ Craig:
    Julian is correct. Laserdiscs were true 1.85:1, but almost all 1.85:1 films on dvd are 1.78:1. If you are using a 4:3 tv this is easily tested by switching the player into 16:9 mode, and if the transfer fills the screen vertically then you have a 1.78:1 transfer.
  17. CraigL
    CraigL Screenwriter
    Jan 16, 2000
    1,863
  18. Jean-Michel
    Jean-Michel Supporting Actor
    Mar 28, 2002
    769
  19. Julian Lalor
    Oct 5, 1999
    975
  20. Damin J Toell
    Damin J Toell Producer
    Mar 7, 2001
    3,762
    6
    Brooklyn, NY
    Damin J. Toell
    CraigL:
