Kodak DP850 (Davis DL450) DLP Projector (1 Viewer)
Tim Smith
I've finally decided to sell my Kodak DP850. I preferred the contrast of CRT over dlp and put this in the closet over a year ago. It has around 100 hours on the bulb.
If you don't know anything about this unit it's a rebadged Davis DL450. It has a 800x600 dmd chip.
More info can be found here at Kodak's site
http://www.kodak.com/global/en/servi...50/dp850.shtml
The projector also comes with the programming cable, so that you can take advantage of some of the 3rd party apps out there.
I'd like to get $650 for it.
Here are some specs
Resolution: SVGA (800 x 600) with compression for XGA (1024 x 768) digital images
Display: Single-chip DLP
Aspect Ratio: 4:3
Response Time: 16 ms
Contrast Ratio: 230:1 (ANSI Checkerboard) 500:1 (ASNI Full on/off)
Computer Compatibility: SVGA, Modes: 56 Hz – 75 Hz; VGA, PC, MACINTOSH, POWERBOOK and others
Video Compatibility: NTSC, SECAM, PAL B/D/G/I/H/N/M
Projection Lamp: 120 W Metal Halide UHP - Ultra High Performance
Lamp Life: 2,000 hours
Brightness: 500 ANSI lumens, typical
Lens: Motorized zoom 1.2:1.7 with 17-degree keystone adjusted image
Focal Range: 5.74 ft (1.75 m) – 16.4 ft (5 m)
Zoom Factor: 1.5x
Uniformity: 85% image center-to-corner
Image Configuration: Plug-and-project auto image positioning, auto tracking and auto synchronization
Audio System: Built-in 10 W loudspeaker
Inputs: Full digital connectivity
Computer (EVC plug)
S-video (MiniDIN/4pin)
Composite video (RCA)
Stereo Audio L/R (RCA)
RS232 connectivity
Outputs: Stereo Audio L/R (RCA)
Vertical Frequency: 48 Hz – 85 Hz
Horizontal Frequency: 15 kHz – 60 kHz
Power Input: 100 VAC – 250 VAC, 50 Hz – 60 Hz, full range
Operating Temperature: 50°F (10°C) to 104°F (40°C)
Dimensions:
13.2 in. (W) x 8.86 in. (D) x 5.12 in. (H)
[335 mm (W) x 225 mm (D) x 130 mm (H)]
Options: Snap-in TV tuner
Tim Smith
I'm open to trade offers. One thing I'm looking for is a laptop with at least a 1GHz processor.
brettjv
