Dan Seliger
- Jun 17, 2001
Asking $200 or trades. Looking for a Monster HTPS-7000 or equivalent (will pay the difference), or a Pioneer LD player w/ Factory AC3 output.
These speakers have never been used, i purchased them and then decided i didnt want to cut holes in my wall so i bought RS-3s instead.
The Reference Series RCW-3 two-way, in-wall loudspeaker’s pivoting square Tractrix® Horn and copper-colored aluminum
woofer are tell-tale signs that it matches every Reference Series loudspeaker just like the RCW-5, RCR-5 and RCR-3. Its Reference Custom standard gold-plated, spring loaded input connectors and industry standard installation kit make it particularly appealing to people who value simplicity and attention to detail.
More info is available at www.klipsch.com just do a search for RCW-3
