Klh Tv?
Discussion in 'Displays' started by Jake Smith, Aug 4, 2003.
  1. Jake Smith
    Jake Smith Auditioning
    Jul 31, 2003
    2
    I can't find any mention of them online. I recently saw a 32" flatscreen at Best Buy for $450. Seems like a good deal as its cheaper than most 27" flats. Is there a catch? What are your thoughts?
    If this TV is not worth it, what would you recommend for the same or lower price? Any widescreens out there for a steal?
    Jake
  2. Jerome Grate
    Jerome Grate Cinematographer
    May 23, 1999
    2,984
    6
    110
    I don't know about KLH, but models like it, Apex or Broksonic tend to have the same picture quality which is o.k. on these types of t.v.s. I bought the Apex 20 inch flat screen model for my son's bedroom for 90 bucks and the picture is not bad. I also put the 24 inch model in the Den for my wife and that particular model has S-Video input. I have to say I was somewhat impressed by that model via S-Video. But I wouldn't use any of these models (Apex, KLH) For a main Home Theater setup. I find that the colors are good but not as true as my Toshiba 32inch or Magnavox 27 inch, subjective as that may sound but I calibrated both t.v.s using Video Essentials and the Magnavox comes closest to the Toshiba. If it's for an area like a guess room or a secondary set other than the main set, then by all means save the money.
  3. Jake Smith
    Jul 31, 2003
    2
    Thanks for the reply Jeremy. My first post and I put it in the wrong place! Sorry about that.
    I have a couple months to figure out what to buy, so I will look at the Magnavox TVs. I want at least a 27" and my max is around the 450 mark.
    Jake
