Wade
- Jun 30, 1997
First of all what do you guys think of the following countertop and cabinet combination?
Countertop - Verde Butterfly
Cabinets - Mastercraft Manhattan
Second, what would be a good flooring choice (type & color) to go with the above combo. I'm thinking a light colored 18" porcelain tile with a hint of gold color added to blend in with the gold in the granite. Is Travertine flooring a good choice for the kitchen? It looks pretty porous and I have read/heard that it can stain easily.
This isn't a custom home but the builder has a lot of flooring options to choose from. The question here is should we go with the builders options which is probably expensive or have the standard flooring (vinyl) put in then replaced by someone else prior to us moving in?
Decisions, Decisions!
Wade
Wade
