Kit 281/81 Question
Discussion in 'Archived Threads 2001-2004' started by Shayne Judge, Feb 19, 2003.
  1. Shayne Judge
    Shayne Judge Stunt Coordinator
    May 8, 2000
    137
    I am in the process of putting together my 281 and 81 kits. When we pre-drilled the holes for the speakers, we placed them all at 12, 3, 6, and 9 o'clock. As a result, the T-nut's overhang in locations where the t-nut is adjacent to an adjoining 3/4" mdf. This causes a gap about 1/16th " that runs almost the entire length of the edge.
    There are 3 possible solutions that I see, and would appreciate recommendations:
    1. Remove the t-nuts that are an issue, and simply go without a few screws on each speaker.
    2. Take a tool and cut out a small piece of mdf so that the t-nut is not an issue and the edges line up flush. Also, the t-nut does not protrude so far out that I would have to cut thru the entire 3/4", looks to be about 1/4th to 3/8"
    3. Fill the gap in with a filler.
    Thanks for your suggestions.
  2. Pete Mazz
    Pete Mazz Supporting Actor
    May 17, 2000
    761
    You could grind a flat on the tee nut so it won't interfere.
    Pete
  3. DaveNaumann
    DaveNaumann Extra
    Apr 7, 2002
    17
    Shayne,
    I just cut a flat spot on the t-nut like pete said, when I buit my 281's. I worked like a charm.
    Dave
