Kipsch vs. Velodyne sub-worth the extra?
Discussion in 'Archived Threads 2001-2004' started by Ron Etaylor, Feb 18, 2003.
  1. Ron Etaylor
    Ron Etaylor Second Unit
    Feb 18, 2002
    275
    I'm considering a Velodyne CHT-12 sub at CC for $600, or a Klipsch RSW 12 for $1250. I could also consider the Velodyne CHT 15 for about $100 more. I have Altec Voice of the Theater fronts. I'm about 65% music/35% movies. Your thoughts would be appreciated.
  2. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
    The Klipsch (although better than the CHT-12) is not worth another $650. IMO, if you are willing to spend $1200 on a subwoofer then there are better options (more bang/buck) than either sub. Read / search some recent subwoofer topics for suggestions...
  3. Cam S
    Cam S Screenwriter
    Jan 11, 2002
    1,524
    Ron, are those prices in american dollars? If so the RSW-12 seems a little expensive. It's a great sub, but isn't exatly the best bang for the buck, however if your concerned with SQ, then it can't be beat.
  4. CurtisC
    CurtisC Second Unit
    Jan 7, 2003
    369
    I had up to 2k subs in my house recently and NONE imo were as musical as the rsw 15,$1250.00 delivered to your door.I don't even consider some of these subs music friendly,some rumble,thump,no I prefer powerfull BASS that musical too.For mostly HT there are other good subs at this price,for music few,and many reviewers agree.If you listen to music/5.1 concerts, bring it home,hook it up you will be impressed!
  5. Henry_W
    Henry_W Stunt Coordinator
    May 7, 2002
    137
    With VOTs I suggest the Klipsch, but at that price range I agree with others on looking at comparatives. For my ear with the VOTs I would only look at Velodynes HGS series as well. Great mains that would benefit from a great sub...
  6. Ron Etaylor
    Feb 18, 2002
    275
    Looks like I'll be researching a bit more. My dealer with the Klipsch has the sticker at $1400(U.S.) but offered it to me for $1250. They will be getting the RSW-15 which will be $1800(I assume I could do a little better).
    Thanks for the input guys.
  7. Khoa Tran
    Khoa Tran Supporting Actor
    Oct 23, 2002
    569
    Earthquake supernova
  8. Phil Mays
    Phil Mays Second Unit
    May 20, 2002
    361
    Ron,
    Push your Klipsch rep for $1,000 to $1,100 on the RSW-12. It is very typical to get Klipsch at a 20% to 25% discount locally.
    If you are a Klipsch fan and and have a local dealer you may be able to get two KSW-12's cheaper than one RSW-12.
    I currently have a KSW-15 which produces more bass than I will ever use. I used to have the KSW-12 that in hindsight I found to be more musical. I wish I would have gotten two KSW-12's.
  9. Ron_L
    Ron_L Second Unit
    Feb 21, 2002
    273
    $1800 for a RSW-15?
    I'm almost sure I've seen a RSW-15 for $999. That's in Canadian dollars too.
  10. CurtisC
    CurtisC Second Unit
    Jan 7, 2003
    369
    RSW 12 msrp 1400.00 US, the 15 is $1800.00.The 12 is a good deal up to 1100.00,the 15 1s a good deal up to 1450.00.You can find them for 950.00/rsw 12, and 1250.00/rsw 15, on line if you shop around.The only way you need the 15 over the 12 is if you have a huge room or must have the top of the line.The 12 will more than surprise most people who demo it at home,it did me.
