Keys Locked Inside
Discussion in 'After Hours Lounge (Off Topic)' started by James Davis, Jun 9, 2003.
  1. James Davis
    James Davis Agent
    Apr 13, 2003
    43
    Never done this before with my car, but I accidently locked my keys inside. I have a '91 Ford Escort, and was wondering if anyone could give me any tips about using a coat hanger? I'm in college so I don't have a lot of spare cash so I'd like to give myself a shot before calling a locksmith.
    My car doesn't power windows or as much to worry about damaging.
    The ironic thing is, 4 days ago I was chatting with my girlfriend and said I should go get my car keys copied since the only one with the spare is my brother 2 hrs away.
    Thanks.
  2. Steve Berger
    Steve Berger Supporting Actor
    Sep 8, 2001
    975
    5
    110
    Are you still on campus? If so ,the Campus Security might be willing to help out. Personally I've never had much luck with coat hangers so I can't help you there. In a small town , even the police might help , but most larger departments don't want to do it anymore.
  3. Craig Robertson
    Craig Robertson Supporting Actor
    May 12, 1999
    982
    find a buddy with AAA and have him/her call and get them to come out and unlock it.
  4. Chris_Morris
    Chris_Morris Screenwriter
    Jan 4, 2002
    1,887
  5. JasenP
    JasenP Screenwriter
    Dec 21, 1999
    1,280
    Kalamazoo, MI
    Jasen
    Please learn from my mistakes:
    Don't lose your temper and rip the rubber seal out of the door to make it easier to get at the insides. :b
  6. Philip_T
    Philip_T Supporting Actor
    Jun 28, 2002
    876
    Does it have a wing vent window? If so, they can be opened fairly easily. If not, see if you can find some lock picks, that year and model can be picked into to. If you can a slim jim, even better, just make sure you put a slight bend in it toward the inside of the car rather than just keeping it straight. Whatever you do, don't get mad and start destroying stuff or breaking windows, it will always be cheaper in the long run to call a locksmith.
    Good Luck,
    Phil
  7. Jay H
    Jay H Producer
    Mar 22, 1999
    5,654
    33
    Pittsfield, MA
    Jay
    I saw a news article about how easy it is to get keys made from the manufacturer (the Ford dealer in your case) just by reading the VIN number off the inspection sticker or the dashboard. Perhaps you can try the same thing. The news reporter was able to get a new car made without any ID or anything, just with the VIN number.
    Although a locksmith is still probably cheaper!
    Jay
  8. Leroy
    Leroy Second Unit
    Jun 30, 1997
    305
    At least you didn't get stuck in a huge mudhole, lock the keys in the car while leaving it running in reverse!! Thank the lord for AAA!!
    I have coat hangered a lock or two. It's not that hard, but as careful as you are, you will still likely tear/scratch something. If the keys are in the seat, I would try and hook those. We had to do that in my cousin's mid 90's Z28. We couldn't bend the hanger so as to pull the lock, so we wnet for the keys instead.
  9. Chris Lockwood
    Chris Lockwood Producer
    Apr 21, 1999
    3,215
    Wow, they built him a whole new car? [​IMG]
  10. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    Lost the key for my Grand Cherokee - $8 replacement from the dealer, but they needed the Title to prove it was my vehicle. OK, great!
    But they didn't work.
    $100 and a locksmith later....
    This was yesterday.
  11. Joe Szott
    Joe Szott Screenwriter
    Feb 22, 2002
    1,962
    Bang, there it is:
  12. DonRoeber
    DonRoeber Screenwriter
    Feb 11, 2001
    1,849
    I've been wondering for awhile now that since we've all got these keys now that have programming information in them, as well as remote entry fobs, why don't they have a sensor in the car that prevents the car from locking if the keys are in it and it's in park. Perhaps a weight sensor on the drivers seat should be implemented as well, incase a person inside the car with the keys legitimately needs the car locked while in park.
  13. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    my friend says the new mercedes keys have some sort of proximity thing-a-ma-jig.
    if the door is locked and you're holding the key you can simply pull the handle and the door will open.
    if you don't have the key and try to pull the handle it stays locked.
    pretty cool.
  14. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
  15. James Davis
    James Davis Agent
    Apr 13, 2003
    43
    I got the keys out today, took a coat hanger and tried on the passenger side. I figured I could live if I messed up the passenger door over the driver's side.
    I have an AAA card actually, it was locked in the glove compartment. Another ironic twist of fate, a week ago I cleaned out my wallet where that card sat for 2yrs and put it in the glove compartment.
