Scott Shanks
I am selling a Key Digital Transcoder KD-VTCA1 for $90.
It works perfectly.
E-mail me if you are interested. Thanks.
TECHNICAL SPECIFICATIONS:
Input:
• One DB15 (VGA) Standard connector (frequently used in personal computers) RGBHV.
• R,G,B - 0.7 volt p-p 75 Ohm terminated, H and V positive or negative TTL sync (switchable).
Processing:
• In auto mode both units automatically adjusts for ANY incoming video scanning format.
• Output scanning format is always the SAME as input scanning format.
• 480p, 1080i, 720p, 60 Hz formats, switchable, in manual mode.
• In Auto mode 480i, 480p, 575i, 575p, 1080i, 540, 720p, 50 Hz or 60 Hz.
• HDTV Colorimetry matrix.
• Horizontal centering adjustment in manual mode.
• Video bandwidth: –3 Db @ 110 MHz.
• Positive or negative input polarity H and V selection switch.
• "Special Sync" mode (switchable) to accommodate Panasonic© Direct View HDTV monitor connected to RCA© DTV Set Top Box.
Outputs:
• Three RCA type Connectors 1 volt p-p, 75 Ohm terminated YPrPb.
Component Video:
• Composite Sync on Y, Pr and Pb.
It works perfectly.
Input:
Processing:
Outputs:
Component Video:
