Steve Ridges
- Jul 26, 2000
Hi. I'm shopping for a new bank and I'm looking at Key Bank but I'm unsure if it will solve a problem I have with MS Money. Here's the situation...
I curently use Bank of America. When you bank online thru their webpage and look at checking account debit card transactions (we use are debit card a lot so this is important), each transaction take 2 lines. The first line is a bunch of numbers followed by the amount. The second line is the name of the vendor.
I just purchased MS Money 2005 to help with budgeting etc. It has a feature where it will connect thru the internet to your bank and download / sync all your accounts. When it does this, Money only shows the first line of each transaction which just contains meaningless numbers instead of the vendors name. I contacted Microsoft about this and they said it's because my bank (Bank of America) is not fully co-operating with the data request and either not formating the data they return correctly or just not returning all the info.
Since I'm looking for another bank for other reasons, I thought I would take the opportunity to find one that is "compatable" with Money. Key Bank is close by and I'd like to try them out. When I asked if they were compatable with Money, they said sure. We're compatible with Money, Quicken, etc. I believe what they are refering to is that you can go to their website and output your account info into a Money or Quicken type file which you can then import. I don't want to do this as it adds an extra step.
Does anyone use the online features of Money with Key Bank? If so, how do they work?
Steve
Steve
