Kenwood vr7070-Manual
Discussion in 'AV Receivers' started by CharlyL, Mar 23, 2004.
  1. CharlyL
    CharlyL Auditioning
    Jan 14, 2002
    2
    Does anyone know of a place/source for an owners manual for the Kenwood vr7070?
    I have tried their website and it contains the models on either side of it (I think)7060 and the 7080.
    Any help would be appreciated.
    Charly
  2. Joshua H
    Joshua H Stunt Coordinator
    Mar 12, 2004
    56
    when i looked for info on my vr-357 i couldnt find anything, eventually i found a sales brochure pdf from its year and found out it's basically the same as the 307, but a different remote. that may be the case for you, i'd advise you to search thru their literature for your model.
  3. Eric A
    Eric A Second Unit
    Jan 3, 2001
    336
    I owned the 7070 and it is exactly the same as the 7080 with the exception of the remote. Unless you need remote programming features, download the 7080 and you will be set.
  4. CharlyL
    CharlyL Auditioning
    Jan 14, 2002
    2
    Thanks, I'll do that
    Charly
