Kenwood VR505 receiver not detecting DD or DTS
Discussion in 'AV Receivers' started by James Herrod, Sep 8, 2003.
  1. James Herrod
    James Herrod Stunt Coordinator
    Nov 27, 1999
    54
    Howdy,
    I'm running an optical cable from my Panasonic DVD changer to my VR505 receiver. I'm not getting any sound and the LEDs for Dolby Digital input on the receiver aren't on. I made sure the receiver was in auto detect and I made sure the DD and DTS outputs on the player are set to bitstream. Any other ideas would be most appreciated. Thanks Much. Jim
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Sounds like you haven't correctly assigned the optical input on your receiver to the DVD player. Do this and you should be up and running.
  3. rin
    rin Stunt Coordinator
    Oct 24, 1999
    233
    Hey neighbor,
    have you tried putting the receiver into digital mode? I used to have a Kenwood receiver that didn't auto-detect incoming digital signal at times. Also, you might have a bad optical cable, can you try the coaxial digital audio connection?
