Brian_Tho
- Jan 8, 2003
How good are the Kenwood receivers?
Check which amps they each have. Kenwood uses two different amps and I am not sure at what level the change takes place. I can tell you that there is a big difference in sound quality between the two even though they have the same wattage.Doug, I actually emailed Kenwood a week or so ago to see if the 6060 and 6070 use the same amps. They haven't replied as of yet. I can say that the power ratings per Kenwood's site are EXACTLY the same, including the THD of each channel. Kenwood also states that both receivers use "K-STAT Discrete Audio Amplifier" instead of the "KAM-1™ High Efficiency Power Amplifier Circuitry" used in their low-end receivers.
I honestly think the THX certification along with the preouts and other additional features of the 6070 could easily account for the $100 difference in MSRP.
