Kenwood VR-6060 DTS Problem (1 Viewer)
Hi,
I purchased a Kenwood VR-6060 several months ago and have been very pleased with it. However, now that I have become more comfortable using the receiver I have been exploring some of the features and have run into a problem concerning DTS playback.
When I select the DTS option in the audio portion of the DVD menu, the sound stops. The sound in the menu continues, but as soon as the actual movie begins the receiver never recognizes the signal. I have the receiver set to "full auto", so it should recognize the change. I have tried switching to the manual option also, but the receiver only toggles between the Dolby Digital and Analog options. I can't get the receiver to switch to DTS as the input DVD audio source. I've tried just about everything and have made no progress, and the instruction manual is no help. I had ran into another problem with the Tru-bass option, and managed to figure out how to deal with it, but no luck with this DTS trouble. I want to pick up some DTS encoded music CD's soon so I really need to figure out how to get the option to work.
I know I can't be the only one to have run into this problem and hope someone out there with the VR-6060 can lend me some advice.
ScottRCapt
James,
Your problem may have something to do with your connection between the DVD player and your receiver. Check to make sure you’ve connected your Digital coaxial or TOS (Optical) cable in the correct place (whichever you are using, you don't need both). If you do not have a digital connection or if it is not hooked up in the DVD/6Ch input, then the receiver will default to analog.
Also, make sure you have the DTS selected in the DVD player menu and that you have an actual DTS DVD playing. The setting on the 6060 should be in auto, as it will sometimes switch from one format to another especially if the previews are not in DTS.
Good Luck,
Scott
Michael Reuben
Michael Reuben
This is almost certainly the cause of the problem, which is one of the most commonly reported issues on the HTF.
Most DVD players ship from the factory with DTS output disabled. You have to enable it in the player's menu (which is different from the disc's menu).
IOW, the receiver probably isn't the problem.
M.
Guys,
Thank you very much!!! It was just a matter of switching a setting on the DVD Menu. I didn't even realize that there was a exclusive menu for the player itself. Anyway, the DTS tracks are working great now. Thanks again to both of you for taking the time to respond.
Jim
ScottRCapt
No Problem James,
That is what HTF is all about, come back anytime...
Once your in and hooked, you will never go back to regular old TV again...
:D
Similar Threads
webbhcjr
