Kenwood Sovereign 5090 A/V Receiver: Good buy for $899.99 ?
Discussion in 'Archived Threads 2001-2004' started by Michael D. Bunting, Feb 16, 2002.
  1. Michael D. Bunting
    Michael D. Bunting Screenwriter
    Jun 9, 1999
    1,828
    Michael
    OPEN BOX item at my local GOOD GUYS - I'm Looking to replace my Denon AVR-3300.
    Is this a good deal???
    [​IMG]
    GENERAL FEATURES
    - AC Accessory Outlets: 2 Switched
    - Aluminum Front Panel
    - Audio Muting: using Remote
    - Auto Function One-Touch Operation
    - Direct Component Control
    - Dual-Room/Dual-Source Operation: Audio and Video
    - Dynamic Rotary Encoder Volume Control
    - Finish: Midnight Black
    - Fluorescent Display: with Volume Indication
    - Front-Panel Display LEDs: Red
    - Full Receiver Control Compliment: Behind Access Panel
    - Last Sound Mode Memory
    - Macro Capability: 3 Programmable
    - SL16 Text Input
    - System Control Connections for Kenwood Components: SL16 Format
    - Variable Input Sensitivity: with Individual Source Memory
    - LCD Display: 4-Line, for Remote and System Set-Up
    POWER RATINGS
    - All Channels-Driven Surround Power: 80 Watts x 5 (1kHz, 0.06% THD, 6 ohms)
    - Stereo Power: 110 Watts per Channel (Left/Right, 20Hz - 20kHz, 0.03% THD, 6 ohms)
    AUDIO FEATURES
    - 6-Channel Analog Audio Input: DVD Audio-Compatible
    - Analog Audio Inputs/Outputs: 11 / 5 (Total)
    - Audio DSP Adjustments: Wall Type, Room Size, Effect Level
    - Audio DSP Listening Modes: 8
    - Bass Management: Full Digital, Dual-Precision, with THX Crossover
    - Digital and Analog Signal Format Detection and Selection: Fully Automatic
    - Digital Audio Input: 14 (7 Coaxial, 7 TOS-Link Optical)
    - Digital Audio Output: 2 (1 Coaxial, 1 TOS-link Optical)
    - Digital to Analog Converter: 24-Bit Resolution, up to 96kHz Sampling Rate
    - Dolby 3 Stereo: Full Digital
    - Dolby Digital
    - Dolby Pro Logic: Full Digital
    - DSP Processor: 32-Bit 2nd-Generation ADI SHARC
    - DTS Digital Surround
    - Gold-Plated RCA Connectors for all Inputs/Outputs (except TOS-Link Optical)
    - Headphone Jack
    - Loudness Control
    - Midnight Theater Mode: 2-Stage
    - MPEG 5.1 Surround Decoding
    - Multi-Channel Music Mode
    - Phono Input with RIAA EQ
    - Pink Noise Generator for Speaker Balancing
    - Preouts: L/C/R/LS/RS/Sub
    - Room B Preouts: Left/Right
    - THX Adaptive Decorrelation
    - THX Bass Peak Level Management
    - THX Front-Channel Re-Equalization
    - THX Loudspeaker Positioin Time Synchronization: 8-Channel
    - THX Surround EX
    - THX Timbre-Matching
    - Tone Controls: Bass, Treble
    PERFORMANCE FEATURES
    - THX Select Certification
    AMPLIFIER FEATURES
    - A/B Speaker Output: Parallel
    - Cooling Fan: with Black Alumite Heatsink Cooling Tunnel
    - K-Ground Amplifier Ground
    - K-STAT Discrete Audio Amplifier
    - Kenwood Ultrasonic Response Amplifier
    - Speaker Connectors: New Double Banana Plug-Compatible (All Channels)
    - Tonorex Audio Filter Capacitors
    DISC PLAYBACK FEATURES
    - DRIVE Distortion Reduction Circuitry: 32-Bit DRIVE III
    - HDCD Decoding
    MINI DISC FEATURES
    - Analog-to-Digital Converter: 24-Bit Resolution, up to 96kHz Sampling Rate
    TUNER FEATURES
    - Automatic and Manual Tuning
    - Direct Preset Call: with Remote
    - Quartz PLL Synthesized Digital Tuning
    - Station Presets: 40 (FM/AM)
    VIDEO FEATURES
    - Front Panel AV/Aux Input: with S-Video
    - Kenwood Universal Video: HD-Compatible
    - Room B Video Monitor Output: 1 Composite
    - Video Inputs: 2 Component, 6 S-Video, 6 Composite (Total)
    - Video Monitor Outputs: 1 Component, 1 S-Video, 1 Composite
    - Video Record Outputs: 2 Composite, 2 S-Video
    CUSTOM INSTALLATION FEATURES
    - IR Inputs/Outputs: 2 (Room A and Room B)
    - IR Repeater Outputs
    - RS-232 Control Input
    REMOTE CONTROL FEATURES
    - Backlight: for LCD Screen
    - Disc Title Storage & Display: for Compatible 400-Disc DVD Changer and 200-Disc CD Changer
    - Learning Capability: IR
    - Pre-Programmed to Control Most Brands of Audio and Video Source Components and TVs
    - Remote Control: PointLess 2-Way RF/IR Learning/ Preprogrammed
    - RF Transmission Bands: 2
    ACCESSORY FEATURES
    - Auto Input Naming
    - Auto Input Recognition
  2. Kyle_Y
    Kyle_Y Stunt Coordinator
    Nov 9, 2001
    238
    No! Look at the power specs, it is 80watts x 5 into 6ohms! not 8! I would suggest an Onkyo 797 or Denon 3802, they are MUCH better than Kenwood Sovereign. The soudn in stereo and surround will be much better, and besides, the 5090 is only a 5ch amp, I would think that in these days, you would want somethign with at least 6 ch for that price on a receiver. Just my opinion, but really 797 or 3802.
  3. Michael D. Bunting
    Jun 9, 1999
    1,828
    Michael
    Kyle
    Thanks for your reply. I did some more research...and decided to stick with my original plan: Getting the Denon 3802 - which I just did.
    I will have it Monday or Tuesday. It is out pf stock right now - but a truck is due in. Unless I change my mind, again.
    Best Regards,
    Mike
  4. Mark Amayao
    Mark Amayao Stunt Coordinator
    Dec 13, 2001
    156
    awesome receiver ..... have you looked at the rxv 2200 yamaha?
  5. iweiss
    iweiss Extra
    Jun 30, 1997
    15
    Sometimes things are not as simple as they seem.
    According to tests of Kenwood receivers in Sound and Vision and Home Theater magazine, the Kenwood Sovereign receivers have met or exceeded their power ratings.
    I wish I could say the same about some of the other brands out there...
