pauld.nz
Grip
- Feb 2, 2004
Firstly, the specs for the amp:
(Intergrated amp/tuner 80 watts pc rms @ 8ohms 20Hz to 20,000Hz less than .09% thd.)
I find that th amp runs the jensons well and i use it for mainly music but also run it through my TV for playing DVDs (using an xbox).
My problem is that i need alot more bass. The jensons are really clear for mid and high but i would love to have alot more bass for music and esp movies. Would it be better to crossover a active sub like the kenwood sw-500 or to buy a cheep surround preamp and use my exsisting kenwood as a power amp. Then go from there ... I expect the later would cost allot more. Im pretty sure i could get a active sub in nz secound hand for around 300 NZ dollars or 150 AMD. But would this just sound like crap without the right sort of amp to run it ?
I have spoted a couple of recievers for auction like a yamaha one
(Model DSP - E300.
12 programs for DSP (11 from actual acoustic environments) plus Dolby Pro Logic surround decoding. Remote Control. 4 or 6 channel operation.
Output power 60W RMS into 8 Ohms per channel. Effect power amp section 15W.) .
Is it posible to use my 2 channel kenwood amp to boost a 5 channel surround amp ?
Im sorry if you guys are confused, i know nxt to nothing about home theater.
Any help would be appreciated
(Model DSP - E300.
