John DeSantis
- Nov 18, 1999
Can someone explain just how you would use the Monitor Audio Jacks. The Manual says you can connect a Graphic Equalizer ( that I understand ) Or a 3 head Cassets, or, Video Component. How would that work? You can't select those inputs with the Input control. A VCR is a Video Component. I don't get it......
Also, I have S-Video out to TV. If I hook my Camcorder up to the AUX A/V inputs, I don't get a pic unless I use an S-Video cable. Is that normal?
