keep my SUNFIRE TRUE SUB SIGNATURE or buy a Dual 16-46CS+ Subwoofer Package
Discussion in 'Speakers' started by ReneZam, Feb 27, 2004.
  1. ReneZam
    ReneZam Stunt Coordinator
    Mar 6, 2003
    56
    the title says it all I have had my Sunfire for three years now getting the upgrade bug good move or stay where im at?
  2. Geoff Costello
    Apr 12, 2002
    16
    RenZam,
    To help people answer you in an informed way, you may want to add some information such as:
    1) Your listening habits (music, HT etc)
    2) Room size
    3) Typical volume you play at relative to reference
    4) Any inadequacies you percieve in the sound from your current sub.
    5) Current sub placement
    Depending on this the answer could be:
    * Keep the Sunfire
    * Get the dual SVS's
    * Get a SVS PB-2+ (or other SVS box model) for your room)
    * Have both the Sunfine and the dual SVS's (other SVS)
    * Consider Brand X (HSU VTF-3 etc)
    Otherwise you will get more "this sub is best" opinions rather than the great informed advice this forum is capable of [​IMG]
    Geoff
  3. Edward J M
    Edward J M Cinematographer
    Sep 22, 2002
    2,031
    Unless there is some other overriding factor, I would advise getting the powered cylinders if you are going to make the switch to SVS. The integrated amp and feature set IMO provides a significant advantage over the passive series.
    Also, the 16-46 cylinder is tuned SO low, it will extend to about 12 Hz in most room in the stock tune. I think for almost all common music and HT applications, the 20-39 cylinder is a better choice, providing a better mix of still excellent extension (17 Hz in most rooms) and stronger (by a few dB) output in the >18 Hz region.
    Ed
  4. ReneZam
    Mar 6, 2003
    56
    here is my info see if this helps
    mainly HT action movies some of my wifes chick flicks etc.
    2) Room size
    25x14 was my garage now my HT
    depends..you guys know how it is if the wife is watching movies with me we have all heard it.."turn it down it doesn't need to be that loud" most of the time i don't know if this means anything we listen to our movies at -20
    4) Any inadequacies you perceive in the sound from your current sub.
    None i just have the upgrade bug..maybe also it the fact i like to feel my movies and the sunfire just is not doing it any more
    I have always had it in a corner from what i have read the sub preforms better in a corner
  5. Geoff Costello
    Apr 12, 2002
    16
    RenZam,
    Hi, thanks for the extra info. Some thoughts for your consideration.Good luck
    Geoff
  6. ReneZam
    Mar 6, 2003
    56
    Thanks Geoff for the help here are a few more tid bits
    Two SVS 16-46Pcs will set you back arround $1750 ($875 each)
    if i sell my sunfire i can still get around 1000.00 for it so i can save up some cash i can be done
    Size of the subs is not a issue wife is cool with the look she likes the svs subs looks better than the sunfire
    i will contact svs and see what all we can do
    once again thank you for your input
