joe_pre
- Jan 28, 2005
Well I bought the above Sony about a month ago, and I do like it, however I've been dissapointed in the standard def image quality. I have it currently set to the settings that CNET suggests. I have a Dish NW DVR 625 running to it via S-video and I think some channels look ok, and some tend to get a little blurry in motion shots. Certain channels are definitely better than others. I also have a DVD player (non-progressive scan) hooked up via component which tends to be much clearer with motion. I plan on sometime buying a upconvert DVD player to really find out what it can do. Am I asking too much from the TV with standard def? It would make sense, and I would understand. I wanted to just make sure that this is what is probably causing my dissapointment. Is this what I should be experiencing? Thanks for the suggestions/comments! FYI... I do (down the road) plan on getting a HD receiver...
Joe
Joe
