I did see it, but alas, it was a cheap tv shop running off a horrible spliced composite. I heard it is nearly as good as the XBR wega, but then again, the XBR wega doesnt have anything on Princetons's 36". But that's just IMO
Blake thanks for the response. I found a couple of guys talking about the set on http://www.hdtvoice.com/voice/index.php under JVC talk thread. You might want to check that out.
I heard it was better than the XBR and lighter too. How important is the DVI/HDTV connection and does the Sony have it? I'm not a Sony fan because of their lack of backup when their quality fails to deliver as promised. I usually am able to avoid.
I'll check out the Princeton set you mentioned.
Regards
Gary
