Rob Michaw
- May 2, 2000
I've had my player for nearly 4 months now hooked up via S-video to a non-progressive tube TV. I'm thanking my lucky stars, and on Thursday I take posession of the Toshiba 42HX81 and I will be hooking it up component via the progressive outs.
My question is, how should I hook the player up? Have the unit switched on to 525p on the back (480 p in practical terms)? Should I have the setting switched via menu to "AUTO"? Should I also have the unit connected via S-vid so I can watch non-anomorphic discs, or do I still watch non-anomorphic discs via progressive? When watching non-anomorphic discs, do I switch the setting on the menu?
Also, if for instance I am watching Gladiator using the "AUTO" or "FILM" setting (and I'm sure it will look great), do I then switch the setting to "VIDEO" via the menu when I watch a making of documentary? (this may be a bad question, because the documentaries on Gladiator may have been filmed anamorphically, but I think you get the idea...if the doc was filmed on video).
Thanks. Any other useful tips would be greatly appreciated.
rob michaw
rob michaw
