Russ Brooks
Grip
- May 26, 2003
I have a model HRS-3800U SVHS VCR that has recording problems. If I record to a new blank tape the recording is fine. If to a used tape there is colored ghosting and ghost lines in the recording. Someone told me once that it may be the erase head that is the problem, not erasing the previous material completely. Was told there is a potentiometer to adjust to increase the voltage. I have taken the cover off and cannot locate it if in fact this is true.
Anyone got any ideas on this????
I am an electronics technician and not afraid to dig into this to fix it.
Russ
Russ
