JVC receiver won't play sound (1 Viewer)
valjoy
Richard
My JVC audio video receiver RX-778v will not play sound. I connected it to TV and BluRay, but no sound. Even the radio within the unit will not play sound. I do not have the remote for the unit. Is it possible that needing the remote is the problem? The system screen will display "automute", but when I click FM mode button, it clears that message, but still no sound. Should I buy the remote to find an option not available on the unit itself, or is something else the problem?
schan1269
HTF Expert
Chicago-ish/NW Indiana
Sam
Have you pressed "speaker A" or "B"? Are you connecting digital sources via toslink? If so, you probably need to assign the input. I found one of Fleabay, but the pictures aren't good enough to "see the buttons" on the faceplate. Typically AVR that old the set-up is the buttons on the front...with no remote control set-up(other than volume levels). But I would get the remote anyway. Or else you may not be able to change individual volume levels. OR just buy the one on Fleabay entirely to have a spare.... http://www.ebay.com/itm/JVC-HOME-ENTERTAINMENT-CENTER-MODEL-RX-778VBK-/300844847476?pt=Receivers_Tuners&hash=item460bc01174
AlohaTiger
