Bill Will
- Dec 26, 2001
I was just poking around Sears website under audio "cleanrance" & came across the 7030 which would make a nice Entry Level Receiver for someone on a budget or a Bedroom Receiver. It has "ALL" the new Surround Formats & the only thing it's missing is DPL IIx but it does have DPL II. I also noticed the Audio Source Speaker Package with 5 speakers & a 8" inch sub-woofer for $80.98 Check the "Closeout" website out because they had a speaker switch box & etc. you just might find something that you could use if you can't get into a Sears store for their Audio Closeout Sale. For the full specs & pictures on the JVC Receiver go to www.crutchfield.com & enter the model number under search & it will come up.
